Roland VS-2000CD Digital Studio Workstation 2000 CD and try to set it up. The only (!) one thing I was able to achieve after a day of work is to switch the station on, connecting to a VGA monitor. The following message is constantly on the screen: "Setup Drive: Load Project: Please wait...." and it goes forever (at least for 12 hours), and the station looks unavailable. It looks like the pre-installed project is trying to be loaded automatically, and the session can't be completed for some reason. Therefore, the all other options are just blocked. I'm not even able to switch from BGA to LCD mode. I have been reading for the documentation very carefully, and have not found the situation described.
So far just one button "power on/off" is available, and the only message:
"Setup Drive: Load Project -> Now working... -> Please wait...."
is seen on the VGA screen for many-many (!) hours.
Please advice, how can I set the VS-2000CD properly?
I have 3 2480s and I use them professionally so I think I can help you. Looks as if you need to install the OS for the system. It seems as if it lost. You should have the OS on CD and if not contact RolandUS and get one. You would put in the OS into your CD burner and power up the unit. I would recommend Roland HD support be on the other end if you are brand new. They will walk you through. I was one of the first to buy the 2480 when it came out and the manual is just insane to learn.
Mike
Same problem, except I've had mine for over two years and it just started. I've replaced the battery but still no luck. I have my whole album on it too. Can anyone help?!?
I have the same problem except I've had my machine for over two years. And, right now I have a whole album on it. I would appreciate any advice that might help.
