My machine leaks periodically. No known reason when or why. This has happened only 5 times since i purchased it. We cannot figure out why or when it will leak. Looking for advice or information on similar problems and remedys
Did you guys ever figure out where the leak was comming from? I've got the exact same problem with my washer. I've taken the front panel off and inspected, but nothing. This is the 3rd time it's happenend to me, like you said, no reason when or why.
Check around and under the rubber front gasket for any trapped items,
if flooding happens open the bottom access panel (3 screws on bottom front) and look for leakage at that time , there is a access door safety switch to the top right that has to be closed to let the unit run.
blow some powder in the bottom to show the wet spots and/or to trace when they happen again.
I've had the same problem. Tonight it flooded my home. I'm beginning to have second thoughts on this model.
