Question about Car Audio & Video
I got 2 1100 watt sony xplod subs powered off a 1000 watt sony xplod amp, everything works fine i just wanna make sure this will be ok and the amp or subs wont blow or fry.
  • 74 Answers
You can blow a sub out when they are overpowered as well as underpowered. Distortion is the main reason thing go out. distortion occurs when you have the volume n the head unit up all the way and the gains on the amp are up all the way. always make sure the bass plays clear and you should be okay
Posted on Jun 15, 2010
SOURCE:
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
Nov 29, 2012 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have two sony xplod 12" speakers wich can hold
You only gave us the model of the amp so I will make an assumption that your 12" subs are the Sony XS-GTX120LW. First, they cannot hold 1200 watts a piece. They are meant to be powered with 350 watts RMS. They will hold 1200 watts peak. That means that 1200 watts for a few seconds will be ok. Past that and kiss them goodbye!
Next you indicated that bridged the amp. Since the subs are both 4 ohm single voice coils did you wire them in series or parallel?
It sounds to me like you wired them in parallel resulting in the amp seeing a 2 ohm load. The amp you referenced is only stable when bridged at 4 ohms.
Has the amp begun working again once it cooled down? If not you could have fried the outputs by having the resistance too low.
Dec 21, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a SONY XPLOD XM1652Z 2 CH 1000 watts hold two 12in subs?
should do easily though you may need to employ the use of a cross over just incase something goes pop and burns you're car out when you park it after you've been hammering the subs.
May 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I have 2 1100watt sony xplods will they run off a 1000 watt amp
yes it will work, but it will only put out the power to the sub that the amp allows, ie : 100 watt amp puts out 100 wats.
you can also try reconfigering your wire to your subs, if your amp is 1ohm stable and your subs you can come off the amp with a bridge and run subs in series or parralell, this will dramaticly improve the bass
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
