Watches Logo
Posted on Jun 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bucherer watch serial number - Watches
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Jun 18, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
846779
Points
4702
Mcdevito75 here, The serial number will be on the movement itself, the number on the case helps but you need to look at the movement for exact ID of the watch
Janice Jackson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 31, 2019
Janice Jackson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3571
Points
I have a bucherer watch seriel number 980540.I would like to know the value
3answers
Where is the serial number on a guess watch
if you can't see it on the back, it's probably inside the back cover.
Loose crown
Try pushing it back in place. I had a watch like that (a Bucherer).
When inserting the bucherer clock key it will not wind the clock
Hi! I need to know the type of clock you have. You are welcome to email me at [email protected] and if possible a picture of the clock and the key you are using. With the above information I will be able to assist you better. Thank you! Yvonne
Jul 31, 2013 • Watches
4helpful
Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Mar 31, 2010 • Watches
8helpful
3answers
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
2answers
Do any Tag Heuer Aquaracers have serial numbers like "abc1234"?
Yes they do;
To see this go to the TAG web site "tagheuer.com" and select "watches".
Now select "aquaracer" and you will see a list of variations.
Jan 16, 2010 • Watches
1helpful
Directions to change day and date on old bucherer automatic watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Mar 14, 2009 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
