I have had the same problem since purchasing my Amana. I have cleaned out the drain line using compresed air even, but to no avail. It appears that the water doesn't have enough slope into the drain hole for proper drainage and therefore it freezes and plugs up. The only solution I found is to keep a piece of large copper wire, or coat hanger wire hanging in the freezer, and periodically, about once a month reach back there and poke the wire in the hole to clear the ice. I think it is a design flaw.I have had the same problem since purchasing my Amana. I have cleaned out the drain line using compresed air even, but to no avail. It appears that the water doesn't have enough slope into the drain hole for proper drainage and therefore it freezes and plugs up. The only solution I found is to keep a piece of large copper wire, or coat hanger wire hanging in the freezer, and periodically, about once a month reach back there and poke the wire in the hole to clear the ice. I think it is a design flaw.
Try removing the strap holding the drain hose underneath that drains into the pan. Otherwise it acts like a p-trap and holds water that then insulates the upper part of the tube. Condensate water eventually freezes high up in the tube and backs up everything pushing the condensate water into the bottom of the freezer where it freezes into sheets. Leaving the drain hose down keeps air in the tube all the way back up into the freezer area. This seems to keep the condensate water flowing freely into the bottom pan. The air in the open condensate tube does not seem to have an ill affects. Also, you can add some stranded bare copper wire around the heating element just above the drain tube inlet and then push the tail off the copper wire down into the drain tube hole. This helps keep any water in liquid form flowing down the drain pipe.
Hello, Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level. With all this it helps to solve the problem....
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
The most common thing that causes this is a stopped up drain. Thaw the ice out of the bottom and locate the drain hole (probably towards the back, possibly behind the back panel) and clear with with a stiff wire or coat hanger.
If the water is unable to drain from the freezer during the defrost cycle it collects in the bottom and freezes there when the freezer is running again.
Hope this helps, let me know if you need further assistance.
This sounds like your Defrost drain is cloged. Do not chizel the ice. use hot water or a hair dryer to remove the ice. Now your either going to be lucky or a little unlucky. look at the back bottom area of the freezer and look for a hole the size of a dime. This is the defrost drain if you see it. If you don't then you will need to pull the power plug from the machine and remove the back wall of the freezer to find the drain. Then you can defrost the ice and then pour hot water down it the defrost that ice and get the drain clear. Its not good practice to shove things down the tube to clear the drain. you could break the tube. if you half to use somthing like a zip tie that is flexable.
Once the drain is flowing water your clear and can put the back wall back together. and plug the machine back in.
Keep in mind that you will need to remove the food and have a place for it while you are working on the machine.
one more thing. try not to pour more that 2 to 3 cups of hot water down the drain. The pan may not hold much more and will spill on the floor behind the machine.
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
most commercial freezers have a drain to the back of the compressor area where the condensate goes into a pan and is boiled off into the air by a loop of hot gas tubing in the pan or an electric heater in the pan. when it defrosts the ice on the coil melts and the water flows out . if the tubing gets plugged the water flows out of the pan and down into the bottom of the box where it refreezes on start of the next refrigeration cycle. clean and clear drain with a shop vac or air hose where water can flow out of pan under the evaporator coil when it defrosts. if you have a domestic residential freezer , most of these have no defrost and neeed to be shut down and manually defrosted every few years. if you leave the door ajar or it doesn't seal well ice builds up and can accumulate in the bottom as frost etc. it would be mosyt unusual for a residential box to have a defrost clock, drain and all, but possible and same rules apply. find the drain and clear with shop vac .
Try taking a small piece of solid copper wire strand, loop over defrost heater and extend into drain hole, this is a trick we use to help with this issue by bringing a little heat around the hole. The freezer may be manufactured by Woods Inc, a canadian appliance builder. These did have lots of problems with the water building up between the inner and outer liners, Not much you can do with these either to totally resolve this issue. Make sure the water is going into the drain pan when you pour the hot water.
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
I have the same problem please let me know if you've found a solution
