The Steps for Newer Style
Console Calibration
1.
Locate the calibration area on
the rear or underside of the console (a hole, near the console's center, that
goes through to the electronics board. (This hole should not have a
screw in it.)
2.
Insert a pencil (eraser
end), into the hole and feel around for the cal button (will click when
pressed).
3.
Press the button 2
times (with the pencil eraser). The first click should show CL11 in
the console, the second click should show CL21.
4.
If the process was done
correctly, and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons on
the console and observing settings. This will not require any other tools.
5.
Press ENTER. CL22 should
display in the TIME window and (??) in the SPEED window.
6.
Press ENTER. CL23 should
7.
Press ENTER. CL24 should
8.
Press ENTER. CL25 should
9.
Press ENTER. CL26 should
display in the TIME window. You should then see the letter
"E."
10.
Press ENTER. You should see
"SS" or "55" in the console.
11. Push the STOP/START button. For safety, at
this point, you should step off, or be off, the treadmill.
12.
Push the ENTER button. The
walking belt should start to move, accelerate to maximum speed, then stop on
its own.
13.
When the belt stops, the
incline should self test by raising to its highest incline
position, then lowering back down to its lowest position.
14.
Once the incline test is
complete, push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
console comes on and operates 1 workout but won't take any other commands get only one speed button works no incline commands stop doesn't work motor and power board ok incline motor ok
