Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
It smells toxic under my jacuzzi tub In my New house the Wirlpool bath"jacuzii" has an access panel in my bathroom lower wall. It smelled like sewage In my bathroom at first so I flushed the roof vent resealed the toilet checked all traps for a dry or low one. I pulled the access panel to look around and BAM The smell of toxic something came out. I looked for a dead animal it would have to be a large dog to smell this bad. I'm very conserned and dont know what to do next? I have small children in the house. Thanks for your time Kris
  • Heather Brown Jan 12, 2019
    Did you ever figure out the cause of the smell? We are having the same issue!
  • Lin Zhang
    Lin Zhang Jan 28, 2019
    I am having the same issue. Can you please share your experience?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 12 Answers
I second the comment on the hair clumps and just the old slimey residues from water? It can smell pretty rank.. Idk about literally a dead animal though.
Posted on Apr 29, 2017
  • Jacuzzi Master
  • 18,031 Answers
Did you see any mold? Did you see any areas that are wet? TOXIC is a term that is used to describe something that is poisonous. I think you mean noxious which means unpleasant and possibly harmful. The smell of sewage would be classified as this.
Posted on Apr 28, 2017
4 Suggested Answers
SOURCE:
  • 19 Answers
SOURCE: smell coming from jacuzzi whirpool tub
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
Posted on Feb 03, 2009
aquaspas
  • 6 Answers
SOURCE: I have a jacuzzi wirlpool bath with a balboa lite
sorry this safety feature is preset by the manufacturer of the component's for liability reasons.
Posted on Mar 22, 2009
  • 120 Answers
SOURCE: whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Posted on Jan 20, 2010
What cleaner gets the bad smell and crud out of jacuzzi jets?
Here is a link to a site that sells jetted tub cleaners.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Any of these cleaners work very well at removing the smell from a jetted tub and the bacteria in the pipes as well.
Rod
US Parts Center
Mar 15, 2014 | Jacuzzi Home
How do I get bad smell and crud out of jacuzzi jets
If you are experiencing a "smell" coming out of the water when you use the tub then you should use one of the products that are made for cleaning jetted tubs pipes.
Here is a link to a site that carries those items. These will get rid of the nasty smell and flecks of bacteria when you use the tub too.
Rod
US Parts Center
Mar 15, 2014 | Home
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
How to put bath supports onto new fibre glass bath.It does not have a wooden frame, do I need to make one?
You mean a tub surround? You have no box for the tub to sit in? What were planning on using to hide the sides of the tub? Most big tubs, whirlpools, jacuzzis, etc, sit in a frame work of two by fours and plywood, the ply top supports the tub and the tile, The ply walls or tile board walls are needed for the tile, access to the motor is necessary if you don't have a panel on the tub itself. The tub is set in a finished box, all the tile work done on the top, and set in a ***** of concrete for support. This is for tubs with no sides on them, some tubs have one side finished, and they go up against the walls, and get tiled over the lip. But they get set in mud too. But no walls, just a band against the wall for support. I have seen every tub in every house we have worked on for 25 years done this way, it works. Check it out. Hope this helps. And I hope this is what you are talking about.
Jun 01, 2010 | Home
Jacuzzi jets smell like rotten eggs when turned on.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Mar 17, 2010 | Home
My jets wont turn on
All the electric power source to all jacuzzi tubs all required to be protected by a "ground fault" device. Have you noticed special wall receptacles in your kitchen and bathroom that have 'test' and 'reset' buttons? There may be a receptacle (or something that looks like a receptacle but without any slots for plugs) near the tub. Push the reset button. If the pump for the tub has an access panel, the device may be behind the panel. And last, the circuit breaker in the main electrical panel may be a ground fault type and needs reset there. Good Luck
Jul 09, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Smell coming from jacuzzi whirpool tub
Feb 01, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
327 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
