Hello Narvaar
I believe I've found what you need.
HERE is the OpenVMS home page
HERE is the support page for all the HP OpenVMS versions through 7.x & OpenVMS VAX 7.x
HERE is the support page for OpenVMS 7.x including manuals.
HERE is HP/Compaq's customer support contact information. If the info. and downloads aren't available on the site, customer support should be able to help you.
HERE is their "Questions Before You Buy" contact information.
Please, let me know if you have any difficulty accessing any of these sites or if you have any more questions at all, comments, etc. We're here to help.
Thank you,
BJ @:)
** Please, don't rate the experts' solutions
** yet. Instead, wait until this issue has
** been resolved or diagnosed and you don't
** have ANY further questions for us. Once
** you enter ratings for the experts' feed-
** back ("solutions"), the problem will be
** closed automatically. We won't be able to
** continue to assist you.
** As long as the problem remains open, we
** WILL continue to work w/ you on it until
** it is resolved or diagnosed.
OpenVMS Freeware distributions
I see references all over that OpenVMS OS is freeware but I haven't been able to find an actual download link yet.
Nor have I been able to find the hardware req's yet.
I have run across a couple of forums (Unix-related). I'm sure you'd get a lot of support and info OpenVMS forums, too.
Still lookin....
Might have to give HP a call. I'll let you know if I can find anything more.
HERE's a forum that will likely be just the ticket for you.
Wow. This site is v-e-r-y well organized (openvms.org)
LOTS of documentation.
FAQs
Open Source and Freeware.
HELP for VMS Beginners
HOBBYIST Forums
IT HTRC Forums
I believe between HPs OpenVMS site and openvms.org you'll find everything you need.
Still, please do, post back w/ any questions, etc.
Lots of information about OpenVMS HERE on Wikipedia.org, too.
The latest stable release, according to Wiki', is 8.3. And, they list it as a proprietary OS which means you'll have to purchase it (from HP/Compaq since they bought out DEC).
Hello Narvaar
Were you able to find the information and a source for the software you are looking for w/ the information and links I provided in my solution?
I did quite a bit of research on your behalf for this your request ("problem"). If my "solution" lead you to what you were looking for, would you kindly take just a moment to re-rate my solution as a "FixYa"? I would be most grateful if you wouldn't mind.
Thank you so much. And thank you for using FixYa!
BJ @:)
Thank you so much, Navaar, for the "FixYa" rating. :)
W/ regard to your new problem...:
We recommend you open a new problem to address a new subject - particularly after your original problem has been rated.
This will enable other experts to see your new problem, too, and hopefully, pull in some more expertise for you.
This won't be difficult (opening a new problem), I promise. Just copy the new problem you've described out of this post and place it in your new one.
Include a link to this post, too, in your new one if you like.
Use a topic for the new problem that most accurately describes the issue (e.g. "Alpha Server Won't Boot")
If you'd like me to help you w/ this problem, I'd be happy to. I can watch for your problem post or you can click on my "Ask Me" button. I will caution you that, while I'm pretty decent w/ hardware, I'm not experienced w/ Compaq's Alpha Servers so, how much in depth I'll be able to assist you outside the hardware might be limited.
I'm game though. We can use some of those forums I found, too. One of the forums in particular I found was incredibly well organized and had a wealth of resources and information.
When you post your new problem or "Ask Me", include any subassembly hardware information you can, too. (e.g. for that riser card your unable to test) Where we can't find info on the model Alpha Server you mentioned, maybe we'll get lucky w/ the subassemblies (motherboard, riser card(s), etc)
This information will give me (or other experts) a good head start. Then we can go from there.
Another thing to do is to, while you're working w/ one or more experts on a new problem here, get one or more posts up on that forum I talked about, too. Let's see if, between the two forums, we can get your issues sorted out or at least diagnosed.
Thank you again, Navaar
BJ @:)
Once you have the new problem posted, please, place a link to it here so I can find it.
Thank you
BJ @:)
First, identify the NIC you wish to change; use:
$ MC LANCP <ret>
> SHOW DEVICE
Next, use the menu driven utility "TCPIP$CONFIG", to set your desired IP address etc:
$ @TCPIP$CONFIG <ret>
Option 1 - core environment
Option 2 - Interfaces (then select your NIC or the IP Addr to change)
Option 2 - add/change a Primary address on *** (where *** is your NIC).
Thanks Pterocarpous for the help. It was very useful.
However can you assist me with the following as well:
The Alpha Server DS10 that is currently being use is not booting up. The power lights just remains on and thats about it. The system board is good, the video card is good however, I am unable to test the Riser card and the memory. What do you think might me the problem???
Thanks in advance
Narvaar
I don't have a problem re-rating the solution as "FixYa", but how do I do it. Seriously I don't know.
Narvaar
Okay I was able too, lol. What do you think about the other problem???
Narvaar
