Compaq Presario M2000 Notebook Logo
Anonymous Posted on Jun 14, 2010
Have compac persario m2000. The power supply will
Have compac persario m2000. The power supply will charge the battery but will not run the computer when plugged in. What might be the problem? The computer works fine until the battery discharges.
Anonymous
Level 1:
New Friend:
  • Contributor 54 Answers
  • Posted on Jun 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
54
Questions
0
Helped
9483
Points
95
The issue might be with the power jack . i mean the port where you insert the charger.. to fix this issue your laptop needs to be repaired.
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
Compac Evo N610c - 2Mhz - 1 GB ram - Windows XP SP2 Blinking charging light went out and computer won't start up again. Checked power suplly (18,57v dc) Replaced with another power supply, replaced the...
Your computer has an open circuit on the system board. If you have data on the machine you can remove the hard drive and connect it to a PC, Sorry I can't think of a more elegant solution. I hope I'm wrong.
My m2000 compaq notebook if I power it on the power led will blink three times and went off, it will not display anthing
Charge it first for sometime before powering it up. If it doesn't help. Clean your RAM card with soft eraser only its edge connector. Do it after you disconnect its battery and be sure that its power supply is also not connected to it. Then put eveything back and power it again.
Hope it helps.
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Hi I have a compaq persario and its the small one 512 80 gb and compac advised i upgrade it but i cant afford it, so is there a cheap way to do it. As I vant afford $160, to upgrade do you supply the...
Sorry it took me a while to track down your computer.  Basically you can hold two 1GB chips in your computer.
This website has them cheap, and these will work in your computer. http://www.crucial.com/store/partspecs.aspx?IMODULE=CT12864AC667
You can also upgrade the HDD as large as you would like, but that is not going to be cheap, and you have a large enough hard drive.
Compaq Presario M2000 DEAD
My power plug that goes in the computer gets hot enough to melt the plastic ring on the end of the plug. so i am going to get a new power board and try that.
2answers
COMPAQ PRESARIO M2000 WILL NOT CHARGE HAS 18V FROM CHARGER
For something like that, I need the Computer, try and open the Computer and remove the Battery the BIOS Battery, and place it back, and see what happens...
Aloha
Kahuna
I want to know how to replace a keyboard on a Compac laptop computer part numberr 367777-001 Compac Presario M2000
Disconnect the
keyboard cable from
the system board.
Lift the edges of the
connector first and
then carefully
disconnect the
keyboard cable.
3answers
New battery will not charge
Hi, Well, first, do you have the correct ac adapter?It's possible to have an adapter that will run the system, but not provide enough juice to run the machine AND charge the battery. Did you replace the battery with a brand new one? Thanks
3answers
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
