Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do I replace the lithium battery in a Casio Privia PX-100?
    Genius:
  • 1,970 Answers
Mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
Posted on Jun 16, 2010
  • olivier
    olivier Sep 12, 2018
    the casio privia px-100 is a piano not a watche
6ya staff
SOURCE:
My g shock ga 100 keeps resetting itself back to 12:00 and the analog doesn't stay synced to the digital i have had a new battery fitted and it still doesn't work any suggestions ??
Did you take your Casio to a pro or it was just a normal battery replacement service?.
I am asking because if a pro did it seems he forgot to reset your Casio watch when battery was replaced.
This is a must when you change battery on a Casio digital watch.
Take it again and ask for a complete reset, if they know what they are doing they will do as you ask without questioning.
Casio Watches
Jul 02, 2014 | Watches
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
I have a Casio 2688 atomic watch and lately it does not hold a charge for a long period of time. It will recharge and then quit within a day.It will hold a medium charge for about 24 hours at most, but...
You likely have a dead battery. Follow the instructions on this web site http://forums.watchuseek.com/f43/how-change-ctl1616-rechargeable-battery-41076.html
it is clear and covers most casio models. Watch closely for the springs when taking your watch apart. You can order the battery online (the best option) but most people that use a standard lithium battery seem to have no problem.
Nov 23, 2010 | Casio PRG-40T-7 Pathfinder
GW-1500A Casio has to be sunlight every day otherwise it stops
Hi gregbrands,
If your watch is several years old, I would recommend sending it back to Casio for service and battery replacement. Contrary to what you may hear about solar-powered watches, the rechargeable batteries do not always last for 10-20 years. I've seen some go out in 2-3 years. This is a shorter lifespan than most standard lithium watch batteries.
You may have an authorized Casio service center near you also. If not, contact Casio at the following numbers:
For Repair support in USA at 1-800-706-2534 during regular business hours (currently Monday-Friday 9:00a.m. - 5:00pm EST, Saturday / Sunday 10:00 a.m. - 8:00 p.m.) For Technical support in USA at 1-800-435-7732 during regular business hours (currently Monday-Friday 9:00 a.m. - 8:00pm EST for all products, Saturday / Sunday 10:00 a.m. - 8:00 p.m)
The cost of your watch well justifies this kind of service, plus, they will assure it remains waterproof up to its specifications.
Let me know if I can help further.
Thanks, Bill
Sep 15, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
Hi I have got casio babyg 163 model.i believe it needs battery replacement but cant find the battery model any help plz
mcdevito75 here, Best Bet, look for a small watch repair shop in your area to cahnge the battery as any pressure on the display while changeing the battery on a Casio watch will break it.
Jul 03, 2010 | Casio BG163-4V Wrist Watch
Watch still not working with a new Renata CR1225 Lithium Battey
while battery on its place touch the 1 End with battery and secound with AC small Gold dot
from
AmFix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 13, 2009 | Casio W94HF-3AV Wrist Watch
For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
May 11, 2009 | Casio F91W-1 Wrist Watch
What type of battery goes into Casio G shock MTG900, Module 2638
CTL is the designation for a rechargeable secondary battery. The CR is a primary disposable battery and is a 3 volt cell. The CTL1616 while the same size as the CR1616 function completely differently and are not interchangeable. The CTL1616 is 2.3 volts and is recharged by solar or light or kinetic movement. The CR1616 is 3 volts is not rechargeable and will not function properly in a time piece designed for a 2.3 volt circuit. There is only one manufacturer of the CTL1616, Panasonic and they sell through Casio parts distribution.
Jan 22, 2009 | Luminox 3102 (Size: ) Watch for Men
Please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Aug 14, 2008 | Casio F91W-1 Wrist Watch
Casio 81cs-36 watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
May 02, 2008 | Casio Black Casual Sports Watch W7521AV...
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
774 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
