there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
do any lights come on with the TV?, like white vizio or orange vizio light. sounds like a problem with the power board. some vizio parts have lifetime warranties so contact vizio support and report your problem. if it is covered the service call is free. there is a green led light on the power board that should come on, if it is not on, you may have a bad power board. to see this light on the power board, turn off the lights in the room and view the tv from the back cover, power board is 3/4 way toward top in the middle of the tv
Sounds like the color wheel shattered. If you google it, you should find information about replacement parts and installation. I had to go through the same thing a couple years ago.
There is a fault in the main processor that is causing noise. The set will have to be serviced. The tech will probably try the main video processing board to start.
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
