Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jun 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get an error of f 29 and my door won't unlock
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Jun 14, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2150317
Points
26471
Hi
Thanks for using FixYa. F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Anonymous
Level 3:
President:
  • Master 1,382 Answers
Anonymous
Master
Level 3:
President:
Answers
1382
Questions
0
Helped
552335
Points
5097
F29 indicates Door unlock error. If the door unlock has failed 6 times this error appears in your washer.
To fix this issue follow these procedures.
1. Check door switch/lock unit for foreign objects.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked.
Thank you !!
Why do doors unlock but can't be locked?
Professional Auto-Tech Expert writes
  • Jeff Armer Mar 29, 2022
  • Won't lock ? power door locks ? with key fob,door switches ? more info.
    Power locks are controlled by door modules and BCM, hook up a scan tool an check for codes .
    Could be door lock relay problem .
    DTC B3125
    Circuit/System Description
    When the door lock switch is place in to the LOCK position, ground is applied through the switch to the body control module (BCM). The BCM then applies a voltage through the door lock relay control circuit to the coil side of the lock relay in the body electrical center (BEC). The relay then engages and applies voltage to all the door lock assemblies.
    DTC B3135 00: All Door Lock Circuit
1helpful
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Maytag 4000 series error code F 29(door unlock error).
Thank you
Jeff Rockwell for trying to help me out.
I did all the step and I replaced it with the new switch/lock that i got for Ebay but still the same problem. I diagnostics using the tech.sheet and still say F 29. Not sure the new switch/lock is bad. How can u test if the new switch/lock is bad?
1helpful
Code f 29
F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you'll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad.
2helpful
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
My Kenmore Elite is getting to hot. It flashes f-29
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated.
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
Check the above link for an detailed article above the same F29 error.
Courtesy:JSROCK - A senior expert of fixya.
F 29
bring it back they have a return guarantee.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
