I have a Xseries 346 server that reboots randomly, It has a Linux O/s and it appeared to reboot when telnet was accessed. We have disabled telnet, which has made the issue better, but it still reboots. Could it be a hardware problem?
Check Light Path Diagnostic which is located on the front side of server . It gives a clue of what's the issue . If you can't see any amber on Light Path Diagnostic , then its an indication of max logs logged on BIOS event logs. You may need to restart server > Get into Bios and clear all event logs . This would remove the information sympol from server .
i have the exact same problem. i bought this server in an auction and i can not install any os on it. have tried ubuntu and centos but neither can find the hard drives.
See page 60 of the Configuration manual for that model located at http://www.abchost.cz/download/262-4/installation-guide-serveru-ibm-xseries-346-2u-s-cpu-intel-xeon.pdf
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Hi While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
