Motorola Mobility L9 Unlocked GSM Cell Phone Logo
Posted on Jun 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have shifted some videos from memory card to phone memory and then move the video from phone memory to another memory card.but that memory cards are not now available. i wants to recover video from phone memory which i have moved to memory card.is it possible and how can i can access to phone memory.or the videos can recover from memory card which is showing the message "unformatted memory card" and than "operation fails"
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 25, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2469749
Points
19564
Internal memory low but memory card is free, how do I move information over to free up space?
Go to your files, such as pictures, music and videos and then look for "move" and choose move to memory card.
Sep 03, 2012 • LG Phoenix
2helpful
VIDEOS SONGS NOT PLAY
Hi there if the camera of your phone is working fine it should perfectly works.But sometimes due to over usage of phone memory/ using of virus infected memory card these problem could happen.So, to fix this Remove your memory card, Scan with currently updated antivirus or move/copy all the files of memory card to PC>> Format the memory card and again move/copy all the files to your memory card.But remember before you insert the memory card to your phone Please Restore the phone by selecting "Restore Setting Only" from the phone setting.I hope that this will completely solve your problem,if the camera of your phone is OK.Good luck
Jul 20, 2012 • Nokia 7210
Memory phone full
hi
sometimes the ringtones from mthe card will go to the phone memory but this is not the problem.
the ring tones are small in size.
each program have to be set card memory or phone memory.
the picture or video is the biggest memory "eating"
i think this is your broblem you have to move all your picture and videos to the card from the phone and than set the phone to use the card for picture and video.
http://www.rylwy.com/
1helpful
2answers
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
1helpful
I can't delete the videos on my phone which are in video player... They dont show up in "my files" so im stuck :( somebody help please!
If you have a mini SD memory card in the phone, you can "MOVE" the videos to the SD card then using an adaptor, put the mini card in the adaptor, plug that into your computer or a friends computer that reads SD memory and delete them there. If you "MOVE" the videos to a mini card they will be gone from your phone.
1helpful
2answers
Showing not enough memory when music or video file is selected
try to save your music and video files in your memory card. maybe some of it are saved in your phone memory. try to move those into your memory card. or if your had acquired your music/video via bluetooth, try to save that into your memory card and DELETE them out of your inbox. that will solve your problem.
2helpful
Insufficient phone memory
hi...
This because you might have stored up all files in phone memory,due to this there no furthur space available for new files. so the mobile says as insuffcient memory.
To delete the content in the phone memory,please open the gallery now you can accesss to the folders in it and you can delete the files or move to memory card from phone memory.
to acess memory
Press 'menu'----->gallery-----> you can find folders like images,video clips,Music files etc,.
please open each folder to delete the content in it or you can move these files to memory card.
to transfer to memory card:-
1.select the file you need to transfer to memory card,
2.Go to options(left navigation key)
3.select move
4.select memory card
Now the files are transferred to Memory card
thanx
2answers
CANNOT FORMAT MEMORY CARD/SAMSUNG HUE
You shouldn't need to format the card. I am constantly switching out cards on various brands of phones, and have never formatted a card.
You should be able to go directly to the video you are wanting to transfer, select Option, then Move.
Copy photos to micro card
first of all you select the photo you want to move onto the memory card and click OPTIONS, then go MANAGE and click MOVE. Then you will get to options MEMORY CARD and BLUETOOTH, click on MEMORY CARD and it will copy to your memoey card. this will work for any pictures, music and videos you want to move onto your memory card
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
