Computers & Internet Logo
Posted on Jun 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have forgotten username and passsword on my router
I have forgotten username and passsword on my broadband router, i have tried a wisard, but nothing happens , any other way than call for help? Regards
AcE
Ps. Its a wireless router and modem in one, Tilgin AB
Model: Vood 452w_b
Goldi Kunal
Level 2:
  • Expert 187 Answers
  • Posted on Jun 14, 2010
Goldi Kunal
Expert
Level 2:
Answers
187
Questions
0
Helped
47867
Points
559
The common username and password are the following:
Username :admin
Password :admin
Username :admin
Password :password
If these does not work try to reset the router to factory default and then the same would work
In order to reset either there would be a dedicated reset button either on front or back of the router,or there would be a reset hole where u need to put in a pin and hold it for 20-30 seconds, if none of them are available press the power button and keep it pressed for 40 - 50 seconds, it should work
2answers
Forgot user name & password to Linksys wireless EA3500. How can I retrieve it?
did you change the username and password on the router
if not
1) it maybe written on a label on the router
2) often it is
admin
admin
if you changed it , then you could try using the factory reset button on the device to return to factory settings
If the router was supplied by your broadband supplier they may have setup a username and password themselves and in which case you would need to contact them
I am trying to connect my iPhone 5 S to my wireless network and have forgotten my password. HELP. To connect to wi-fi I need a password and can not remember the password as this router was set up years ago
Firstly log into your router from your computer. If you don't know the username and password, try the default one which is Username: admin Password: Admin. Check under Wireless setting and you will see the current password listed there. You can change it to a new one if required. Just remember to save after you've done any changes.
I forgot my paswordhow do i reset it
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Forgot the password
If you have forgotten the password and haven't set it, try using no password. The default password is blank and the default username is Admin. If this does not work and you have no way of guessing your password, you will need to reset your router. This should only be done if you know your broadband username and password as it will wipe to blank if you reset and you will need to type them in again.
Trying to setup my wireless on an older Lindsys, wirelessG, Broadband Router, Model #WRT534G. When I loaded my disc, I got error reports. Just got a new service provider and am trying to connect my...
If you had forgotten the username and password you will want to reset your router to default settings after secure your router with a new username and password.
To do that you will want to press and hold the reset button on the back of your router for 15 seconds or until router resets after you can secure your router once again copy and paste the link into your address bar.
http://vectrosecurity.com/content/view/49/26/
I have linksys wireless router and am trying to get wi fi on a recently purchased Kindle but Have forgotten my Linksys password. Please help
Hi nancylousdol,
If you have forgotten your password you can reset the router to its factory state and setup a new password for it. Resetting the router will wiped out all changes that have been saved. To reset the router, look for the small hole at the back of it. Press and hold it for 10-15 seconds using a Pen or Paperclip. Then access the router settings page so that you can personalize the settings.
For you to access your router you need a working computer that is connected to the router and open a browser type 192.168.1.1 to he address bar and it will ask you for a username and password. The default username is "leave it blank" and the default password is admin.
Rate me if this helps so i can help others.
Thanks for using Fixya
Got a new computer and I am trying to set up my network but I have forgotten my username and password to log into my network. How do I obtain this information?
If you didn't change it by default it is:
username: - leave blank - password: admin
Everything related to your router is HERE.
Hope this info helps ;)
AirPlus Extreme Wireless G Router-Can't reset Username/Password
on this router, leave the username blank and enter admin in the password box.
Forgot username/password for Dell Wireless 2350 Broadband Router.
Do you mean you have forgotten the wireless password for your network?
If so , there is are several tools available online which recover the wireless key as long as you have previously connected to that network from your computer.
Try http://www.nirsoft.net/utils/wireless_key.html
Broadband Router is asking for username and password
If you haven't setup a username and password on this router before.
Then it's probably using the factory default username and password, for that visit the manufacturer's website.
If you have setup a username and password before on this router, but forgotten what the password is. Give the router a hard reset. How to do that can be found in the manual.
Grand Canyon Tech
Grand Canyon Tech
