These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
SOURCE: need codes for universal remote
JVC TV CODES:
060 026 197 069 247 923 012 065 067 141
NEED STEPS RE PROGRAM MY TV. I LOST INSTRUCTIONS. I DO HAVE CODES.
THANKS
SOURCE: Need code for Jvc tv by using RCA remote
google the remote model number and you should find all the codes
SOURCE: Need code for JVC television
I cannot find mine right now. Go to WalMart or K-Mart or Target and see if you can read the possible numbers on the back of the blister pack. If they are inside, buy another even if with less buttons, 3 vs 5, and get the list. They are cheap and just about everywhere.
Google is your friend.
JVC ...................... 007 107 108 308 510 607 902
-Ken
SOURCE: The sharper image jumbo universal remote jvc tv
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
