Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
It sounds like the clock itself could be faulty or a bad connection somewhere,check the clock connections and the selector switch for the main oven functions.Also check the incoming supply cables.There is also a thermal cut out normally at the rear of the cooker behind the back cover (looks like a small round disc 1/2" dia.with two wires to it check this first with meter.).If you need any part numbers and prices send a message.
Hope this helps.
Hope this helps.
suggested this in manual but clock has been checked? No power at all lights or anything
