SOURCE: 1998/99 Dodge Dakota clutch and manual transmission problems
clutch needing replaced, very common on all manuals
pedal travel adjustment,yes
gear shift adjustment,no
SOURCE: open throttle to full. clutch wont enegage for 3 to 4 seconds
Try a new belt, it may look fine but can be polished and have no grip left.
SOURCE: transmission issues (I think)
Use a engine scanner to pull codes, If none it sounds like the lock-up torque converter may not be disengaging at idle. Or you have a idle air control valve or TPS going bad, then repair codes by replacing failed sensor or shift control solenoid as needed. If no codes are present your transmission could have a internal failure. It's also been know that oil transmission fluid in the system will have a higher fluid retention causing the 2nd gear solenoid to stick causing the transmission to stay in second till the line pressure rises and drops back to first with a hard shift. Keep me posted be glad to get your transmission running again.
SOURCE: transmission problems
This is what my 04 Kia Rio is doing exactly. I was told that the TCM and Shift Solenoid "C" is faulty. Am trying to figure out how to go about fixing that without paying more than the car is worth. My tech checked with the local Kia dealership and the TCM new is I think around $700. You also have to buy the program to tell this high dollar part what to do and that is right at $100. I have found that sometimes if I let the car warm up and then keep hitting the overdrive button, eventually it starts shifting correctly.
SOURCE: hey i have a kyosho FW06, i recently crashed it
Check the batteries have not been dislodged at all,
if there is internal damage you could try contacting
Kyosho Toys
http://www.kyoshoamerica.com/contactus.php
