you can use the unit as an external drive, you will need to connect the it to your computer via usb then power it up, after 30 seconds or so it should show up on "My Computer" as an extra drive.
if it doesn't show then the internal battery could be flat, though it will charge via the usb if the power is off (red light on when charging) or use the supplied power adapter.
yeah, man, i did the same. cracked the glass, without damage to the screen, and then just made one myself, cutting it out from a cd-box and then glued it on :)
Problem is once the hard drive is corrupted you can't access usb to fix the problem. You have to remove the four screws on the back cover remove the 40gig hard drive. Find a laptop or an ide to usb adapter to reformat the drive. Must be fat32 not ntsf. Then copy all files back onto drive.
The restore files are here. Mustek don't seem to support it any more You will also need to download the manual for instructions. http://www.driverstock.com/Mustek-PVR-H140-driver-download/31-34-9027-69537/index.html
