My Whirlpool Duet Sport HT front load washer flashes F30 and does not fill up with water. What does F30 mean.
"F30" indicates "DISPENSER SYSTEM ERROR"
When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of the dispenser.
3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU).
4. Check dispenser motor for powered rotations.
Thank you !!
The F30
code
refers to a failure of the dispenser motor. You may hear an clicking sound. The clicking you were
hearing was probably the dispenser motor switch going on and off trying
to activate the dispenser motor.
of the dispenser.
Error code F30 in my case was generated when the plastic link bar forced the teardrop shaped cam over a small plastic pin stop. The cam was trapped on the wrong side of this small pin and could not be rotated by the linkage. Removing the linkage and repositioning the cam solved the problem. Why it jumped the "fence" in the first place is a mystery. Time will tell if it reoccurs. It may be that the cam over time becomes too flexible allowing it to jump over its stop point
The water comes in but flow into washer so it comes out from under the dispenser drawer when I first start a load
When iI put a load in my Whirpool Duet Sport washer and start it,the water drains slowly into the washer so it flows out from under the dispenser drawer.
