Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
Posted on Jun 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much chan lubricant should be used and what is the grade of the oil
Anonymous
Level 3:
  • Master 3,600 Answers
  • Posted on Jun 13, 2010
Anonymous
Master
Level 3:
Answers
3600
Questions
Helped
1575023
Points
11774
You want to buy Bar grade oil, it is sticky and stays on the chain, it will properly lube the bar and chain with a full tank o gas. People have used, used motor oil but this wears down the chain and gears from the micro sized filings in the oil so use clean bar oil to lube the chain correctly. also if the chain sprocket has a small hole in the tip of the saw you will need to buy a gear lube pump to keep grease in the gear at the tip of the blade. This should be lube each time you fill the fuel tank and once half way threw the tank of fuel to make the bar last longer. The bar oil is a special grade of oil and requires bar oil for it to adhere to the bar and the bar guides. Hope this helps and thanks for using fix-ya.
What is the importance of viscosity in automotive lubricants?
The "viscosity" of a lubricant refers to its ability to resist flow. There are two cases, either the viscosity is high or it is low: the lower the viscosity (0W/5W), the more friction is reduced, providing energy savings.
4. Why is the viscosity of an automotive lubricant important?
https://www.igol.com > 4-why-is-the-viscosity-of-an-auto...
The Importance of an Oil's Viscosity - Machinery Lubrication
https://www.machinerylubrication.com > Read > oil-vis...
The Importance of an Oil's Viscosity · A general increase in viscosity at higher temperatures, which results in lower oil consumption and less wear. · A reduced ...
What Does Viscosity Mean (and How Does it Affect Your ...
https://blog.amsoil.com > what-does-viscosity-mean-an...
Sept 2, 2016 - Put simply, viscosity is the most important property of a lubricant. How it reacts to changes in temperature, pressure or speed determines how ...
The Importance of Viscosity - Finol Oils
https://www.finol.ie > news > importance-of-viscosity
Apr 15, 2020 - Today, the vast majority of vehicles run on a multi-grade lubricant. If you take a 5W-30 engine oil for example, the lower the number, the ...
Oil viscosity and oil grades ' v2lubricants - TOTAL Lubricants
https://lubricants.totalenergies.com > maintenancetips
Engine oil viscosity refers to how easily oil pours at a specified temperature. Thin oils have lower viscosity and pour more easily at low temperatures than ...
Oil Viscosity Explained - BuyGreatOil.com
https://www.buygreatoil.com > oil-viscosity-explained
May 28, 2018 - Viscosity is the most important property of oil when considering engine protection. Viscosity determines how your engine's lubricant will ...
HI I AM LOOKING FOR A FOOD GRADE SEALANT THAT CAN BE USED ON THREADS ON A PIPE USED FOR A VERY LIGHT GRADE OIL
Here are a three places that sell food grade lubricants-
www.webstaurantstore.com/.../food-grade-lubricants-and-food-safe-lubri.
- www.lowes.com/pd_403826-75041-10340_0 and
1helpful
Oil type for 2006 dodge grand caravan
New cars and truck manufactures recomend differend types of grades of oil when the engine is new. What they don't tell you when the engine receives 30,000 miles on it the grade of oil can be changed for better lubrication. Use 10w30 for normal use upon changing oil.
1helpful
2answers
I have bought a 2nd hand pulsar 150 2006 it has got an overheating problem and the engine is very rough (too much vibration)
its either too lean(runs hot, causes vibrations, hesitates on acceleration) or there is a problem with the lubrication system(not enough oil to the piston = alot of friction=running hot. hope that helps
2answers
Need engine oil capacities for a 2.7L Hyundia
Lubricants and capacities
Engine oil options
Ambient temperature range Cold climate
Engine oil grade SAE 5W/30
Engine oil classification API/ACEA SJ/A2
Ambient temperature range Moderate climate
Engine oil grade SAE 10W/30
Ambient temperature range Moderate climate alternative
Engine oil grade SAE 10W/50
Ambient temperature range Hot climate
Engine oil grade SAE 10W/40
Engine with filter(s) litres 4,5
2answers
Oil choice
I would consult your local dealer or owners manual for the proper oil. The oil must be diesel rated and have the proper viscosity so that the bearings are lubricated as well as the piston skirts. If you live in a colder climate, a thinner grade of oil may be needed as to a summer grade.
18helpful
What type of oil,oil filter and transmission fluid do i need? for a straight, 5 speed 93 jeep wrangler?
Jeep Wrangler/YJ 1987-1995 Repair Guide
Engine Oil
Fig. 1: Be sure to select the proper API quality classification and SAE viscosity grade of engine oil (10W-30)
Oil FIlter (K&N sample)
HP-2004 work for 2.5L and 4.0L
Manual Transmission
The level of lubricant in the transmission should be maintained at the filler hole on all manual transmissions. This hole is on the right side. When you check the level in the transmission, make sure that the vehicle is level so that you get a true reading. When you remove the filler plug, lubricant should run out of the hole. Replace the plug quickly for a minimum loss of lubricant. If lubricant does not run out of the hole when the plug is removed, lubricant should be added until it does. Replace the plug as soon as the lubricant reaches the level of the hole.
Fig. 1: Manual transmission fill and drain hole plugs
DRAIN AND REFILL
Remove the drain plug which is at the bottom of the transmission. Allow all the lubricant to run out before replacing the plug. Replace the case with the correct viscosity oil. All manual transmissions use SAE 75W-90 API quality Grade GL-5 gear lubricant. Tighten the fill hole plug to 27 ft. lbs. (37 Nm).
I hope help you with this (rermember rated this help) Good luck.
12helpful
2answers
Where can i put lubricating oil for karcher jet wash machine
It sounds like you are referring to the oil in the swash plate housing. You can use a multi grade motor oil such as 20w50 or 10w40. Fill to about half way over the swash plate. If the old oil has gone amilky colour, please replace the oil seals first.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
