It won't turn on. It worked last night and I plugged it in before I went to bed, and when I woke up it was black. It won't turn on now or make any type of sound.
First, try resetting it. There should be a tiny hole in the back of the player. There is where you reset it. Gently push small pointed object in tiny hole and this will reset it. If that doesn't work, plug it back into your computer and make sure your computer is recognizing it. Click on Computer and see if it is showing up whatever drive you have it in.
Try removing the battery and clean the contact's, then reinsert the battery and let it charge, if it do'es not begin to charge your adapter may need to be replaced, or your battery.
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
