Is it getting any better if you move closer to the router?
First try to update the driver and see if it works better, if not than there's not really much you can do with it. You can swich to cat5e cable, that will be more than enough, or if you really need wireles speed than consider changeing the wirelesscacd in your laptop.
I suggest you some atheros chip based card, because their signal strength and sensitivity is very good. First figure out what you have, open up the small backpanel of your laptop, if there's two than it could be the bigger one. The card could be
Mini PCI or mini
PCI-E wichever is similar to your card is the type that you need.
After that go to ebay and search for
"atheros mini pci" or
"mini pci-e atheros", see description for compatibility, or ask the seller if you are not certain. Delivery usually takes about up to 5 bisness days.
Depanding of the card's exact chip you can download driver from
here.
Just check before ordering if there's a driver or not for your OS, because as you can see they don't have drivers for some older chips if you have a relatively new windows like Vista or if the chipset is new in some cases there's no driver for XP
But for most cards there's a working dirver and it really makes a diference after most cards.
To swich the card:
-Download the driver for the new card.
-Uninstall the current wireless driver in windows and shut down the computer.
-Swich the wireless card for the new one.
-Start the system and install the driver.
-Enjoy your new card.
