I just got a Toshiba tablet. I love it! I find that the pen, however, is too sensitive (i.e., hovering over a menu item will open the menu without having to actually touch it). Can this be adjusted? Also, what is the function of the button on the side of the pen? This pen came with absolutely no documentation. Can I get some documentation on line? I thank you for any help you can give me.
Sal
SOURCE: Bamboo fun tablet pen not working
After having almost the same problem (I did not check to see if the eraser was working), I changed the nub (my bamboo came with a little bundle with tree of them. You can change it by bitting the tip to get it out and them inserting a new one.)
The thing is, it did not work at all at the time, but after the week end it came back...
Not much help...
SOURCE: Wacom tablet won't recognize pen
Hmm. I've had a similar thing happen with my tablet. Have you tried removing the tablet pen from the list of tools in tablet preferences and then adding it to the list again before checking the 'About' section of the tablet pen set-up and clicking the 'diagnose' button there in? As that worked for me when my tablet pen was not working. The pen was recognized by the tablet after that.
SOURCE: Wacom Tablet overly sensitive
I also had this problem. Then I tried changing the frimness of the pen, and now it works perfectly fine.
Go to Pen Tablet preferences, then in the Pen tab, change the softness scale to "Firm" then it should be fine.
SOURCE: Recovery CD
ok you wouldn't have been supplied a recovery cd, you have to create it, to create one have 2 blank dvd discs ready and go to start menu and select help type in a search for recovery cd, this will explain how to create one....if your computer won't load into windows you will have to re-install windows again, cheers, any other probs please get back to me.
Brett.
SOURCE: how to use the toshiba pen
First, go to your control panel and find the icon for the pen. Next, calibrate the pen and set up how you want it to work. The pen is not for use in every program necessarily but with handwriting recognition activated and a charactes set entered, it will wirk. It is also good for graphics, with a bit of practice. Some units let you erase with the back of the stylus, just like a pencil eraser.
