Sir
i have recently purchased IR 400 canon photcopier
my problem is the machine is giving error 805 as soon the machine is started
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
What can i do for my machine canon IR400's problem error numis 805.
give me a right solution this problem
Canon ir400 PS Errer For E805
805
One of the fan is not rotating in the machine.check all the fans.
(or) go to service mode select COPIER>ERROR and see the sub code be side the E805.its like (0002).see the sub code and post it
Write your answer.. 805 cod erer
SOURCE: canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
i have been using IR 400s i would like to know whether fax facility is available in this machine or not and whether i can increase the memmory of the machine?
i want error code list
ir400
sar,
iam purces ir 400 photo copiar this mision copy on the lines come
ir 400 Error code 014 solve problem
what is the wattage for IR 400 MACHINE. CAN i RUN ir400 by INVERTER
error code E000732-0010
