Ryobi Cultivator Logo
Posted on Jun 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the Gas /Oil Mix Ratio on the Ryobi Tiller Model RY60511A
Tom
Level 2:
Champion:
  • Expert 221 Answers
  • Posted on Jul 01, 2010
Tom
Expert
Level 2:
Champion:
Answers
221
Questions
0
Helped
137152
Points
429
50:1 is the recommended. I hope this helps.
  • SA Bailey
    SA Bailey May 02, 2017
    32:1 is shown in the owners manual, after reading the small print I found a statement saying use 40:1 in California. In manual it shows use 4oz 2 cycle oil to 1 gallon gas to get 32:1 ratio.
3helpful
What is the mix for gas and oil in a ryobi tiller, model # ry60511a, 25cc
To make your day a little bit easier, you can buy the one gallon mix bottles of oil from Lowes, Home Depot and Walmart. Just goto the lawn and garden department and there you will find these bottles of oil. One bottle to one gallon of gas.
5helpful
3answers
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
1helpful
Ryobi Tiller, model RY60511A, will not start. Air
mine was a total pain. I yanked on the rope so many times, it flew out of the keeper,and when I replaced it I ran it UNDER the fuel tank cutting a slot in tank. I also blew out the primer bulb. AFTER the replacement tank I arrived, I discovered rolling the machine forward helped the flow to carb and did not require priming. Now I need to fix throttle cable. But all in all, a tough little machine.
2helpful
What type of oil goes in the Ryobi 08570 Blower? What is the oil gas mix ratio?
You need 2 stroke motor oil or chain saw oil.Mix it according to the lable to make up 50:1 oil/gas mix.
2helpful
What is the oil to gas mix ratio for ryobi tiller
some of the new models are 4 cycle, hence you dont mix it.The 2 cycle models are all 50 to one of a good synthetic 2 stroke oil
How to mix gas and oil ratio
hello. the mix has not changed over the years. it is important however to use ryobi oil. go to any home depot and get the small bottle of ryobi oil that is enough for just one gallon of gas, use new gas fresh from the pump, and enjoy.
5helpful
Ryobi gas blower model #ry08570 need gas and oil mix
try 40 to 1 ratio it should say on the blower if not check the ratio on the bottle of 2cycle oil it will tell you how much oil to add to a gallon of gas
8helpful
2answers
2answers
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
