Canon SmartBase MP730 All-In-One InkJet Printer Logo
Posted on Apr 12, 2008
Printer My MP730 Canon Imageclass printer/copier/fax/scanner has stopped printing and is showing a ##334 error code. What do I do?
  • 1 more comment
  • Anonymous May 07, 2008
    I have the same problem, tried that didn't work.
  • Anonymous May 22, 2008
    error ##343
  • Brenness May 28, 2008
    same problem. Have gone through all maintenance procedures to clean heads. Error message #336. Wait cooling and check printer and press resume cycling through on alarm panel. Print quality has slowly been getting worse over the last few uses but now won't print at all. Sigh !
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Apr 12, 2008
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
23268
Points
68
#334 is an eprom error, try turning it on and off to reset it, if it doesn't work there might be a problem with the main logic board.
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
2answers
2answers
ERROR E733-0000
Hello I have the same problem my canon still showing error e7330000.Help me fix the problem.
I did some copying with my Canon ImageCLASS MF4450 and now it won't print from the computer??
go to printer folder from control panel
double click to imageclass see there is some printin quque
delete all print jobs
also right click to printer see there printer is offline make it online then try to print
1helpful
Error ##334., its my problem
The error code ##334 represents a EEPROM check error. The manual says this means the Printed Circuit Board may need replacing, however, try this procedure.
Insert paper into machine.
1)To enter service mode press Menu, copy, #
2) Select Test Mode with the + or - keys
3) Press OK
4) Press 8, lcd shows 'Please Wait', after wait, press 3, the lcd then alternates between 3-0 (EEPROM clear), and 3-1 (Purge flag)
5) When EEPROM clear (3-0) shows in lcd, press 0, then OK, then Stop then press the OFF button.
Repeat the above from Step1 to step3
in step 4 this time reset the Purge flag by pressing 0 when 3-1 shows in the lcd, OK, Stop, Off.
If the red fault light is still blinking press Resume.
hope this helps
1helpful
Connon mp730error ##334
#334 is an eprom error and if turning on and off does not reset it, you have something going on with the main logic board.
http://printer1.blogspot.com/2009/01/canon-multipass-mp730-service-manual.html
Above is a service and repair manual this will assist you to troubleshoot and hopefully repair, although I fear with this type of fault, it needs to be returned to the factory.
2answers
Canon image class MF5750 printer/fax/scanner
If you're in the USA, go to this link. Enter your zip code or city / state and click the "Find Service Location" button.
Hloo I need hilp
sounds like you have an empty ink catridge. even though the catridge doesn't look complete empty the sensor can decide it is and won't work until you change the cartridge. You might want to remove and reinsert all of the cartridges making sure they are in the proper slot and properly setted.
Printer not work
My printer will print on every type of paper i set it to in the preferences, except "plain paper". the machine also doesn't copy when set to plain paper also. I printed a report cover on matte paper which printed fine, but when i change back to plain paper, it doesn't print.
old marine
old marine
ZJ Limited
ZJ Limited
