SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
SOURCE: "CH 01" shows on the display screen
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
SOURCE: dehumidifier won't turn on
Make sure the buicket is seated all the way. Sometimes it doesnt fully engage on the left side. If it is then it may need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
SOURCE: Will not turn on
Boys and girls, I hate to tell you this -- but those units are DEAD. I had the same problems as being discussed here (not turning on, electronic chirp, bucket full signals), but with one other important feature -- the unit became so hot that I couldn't touch the top. At first it sounded and smelled like the fan was jammed, and later it sounded like the compressor wasn't working.
Anyway, after two weeks of dealing with LG (1-800-243-0000, and be prepared to call back several times as they have a phone problem), they have finally decided to refund me the money on my unit. Give them a call and speak to them. Also, as my unit was intermittently working, I would recommend that you unplug your malfunctioning unit if you are having these problems. A dead dehumidifier is one thing, a house fire is quite another thing.
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
Problem It shows Bucket Full
heatman101
Here
Dehumidifier
heatman101
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
