Asko 24 in. D3350 Dishwasher Logo
Posted on Jun 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer controlled dishwasher - f2 key- telsa
Anonymous
Level 2:
Sergeant:
  • Expert 351 Answers
  • Posted on Jun 16, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
351
Questions
Helped
167276
Points
619
Water in flood pan tilt dishwasher back to reset and test for leaks and blockages
Fault code F2 on lg dishwasher what does it mean ?
dishwasher error code e2 f2, means main control board is not getting correct signal from the user interface https://www.skypesupports.com/
Samsung dishwasher why is F2 not explained
Hi, F2 means that the Main Control Board is not getting the right signal from the user interface, turn off the power to the machine & then go to you tube there are several videos showing the correct way to remove the screws to give you access to the inner door liner to check all the contacts are clean & connected properly, as if this doesn't correct it then the user interface is probably the cause as it is most likely faulty & needs to be replaced, but to be sure I would follow the step by step tutorial on you tube for your make & model....
I hope this helps....
Cannot enter bios in the standard way with F2. I believe IDE controller is set to disable
Turn on your computer. If your computer is already on, then reboot it.
You need to see the initial display screen to get into the BIOS.
Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information.
The majority of Gateway computers use the F1 key.
If, for some reason this does not work, then use the F2.
All of Gateway's desktops use the F1 or F2 keys.
hope this helps
1helpful
Fault code F2
F2 - Rotor may be jammed - blocked, the rotor has failed, hall sensor cold be faulty, faulty stator windings or there is a faulty electronic controller, the other could be the mains power filter.
So as you can see there a number of components that possibly be the cause, will rerquire the services of a serviceman familiar with F & P disdrawers..
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
How do i get to bios to check my usb is switched on
DIFFERENT COMPUTERS USE DIFFERENT WAYS.ON STARTUP, HOLD DOWN F2 KEY WHILE STARTING UP, OR, INSTANTLY WHEN SEEING F12...F2 PROMPT PAGE HIT F2 KEY...hope this works.
you could go to control panel;system, usb and see if you have yellow ??? or red x's...or with computer on, unplug an USB DEVICE AND SEE IF YOU GET AN ERROR AT LOWER RIGHT OF SCREEN;plug it back in, and computer should see it.
9helpful
Range flashing code f2eo
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open
Problem with keys used to enter the cmos
For Toshiba notebook PCs manufactured since the introduction of Windows XP, one or more of the following methods will be effective:
  • Toshiba Hardware utility method: Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
    If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below).
  • F2 key method: Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
  • Esc key method: Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For more information search on toshiba web.
Thanks
iqbal
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
