The non-gmail mail app does not support changing the signature on the version of Android OS that is loaded onto the HTC Dream/G1. In the Gmail app do the following:
1. push the menu button to bring up the menu options for the Gmail app. 2. select settings from the menu 3.select signature and enter your desired message 4. press OK to save or cancel to void your entry.
you cant really put a signature on them but you can insert smlieys by hitting the menu on the home pad and selecting insert smiley face and scroll through to select which one you can use or want if you have any tech prob and you have windows seven scan your device with the windws os while its hooked up to your computer
You have to download an application called text easy bt that will only give u a signature for every new message. In order to get a signture under your original text message is you have to go into text easy, select the person or perons you want to send a text to ( bt dnt write nothn) Then jus go back and it will be saved in your drafts into the messaging icon
the RAZRs wont add a signature, even if u put one in. i have the same problem on mine. Ill c wat I can do, but idk if i can get it 2 work. A nice fone 2 get wud b a samsung, THANKS 4 RATING
