Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Posted on Jun 12, 2010
Oven wont work. alarm with f13 shows
Oven wont work. alarm with f13 shows wen try to turn it on
  • Anonymous Mar 20, 2014
    oven not coming on
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
685
Points
Showed f1 for oven not working
2answers
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
Exact same thing happened to me. After a power failure my Frigidaire stove worked and the clock worked but bake broil and self clean gave me a DR error. Tried everything to reset nothing worked. When I unplugged and plugged back in I got an f13 code.I changed the control board and the entire oven is back in business!c86f7aab-24e4-4403-bcd6-0b838d53ac57.jpeg
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Code (numbers/letters) are shown when trying to use oven (F13)
Try shutting the power down for a couple minutes and this may reset the control If it continues then you will need an error code guide to see what is causing the problem. Sometimes there is a little mini manual on the back or inside the control panel. If not you may need to call for service.
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
1helpful
I HAVE A FRIDGIDAIRE STOVE AND OVEN MODEL #PLES389CC SER. #NF54421685 AND WHEN TURNING ON THE OVEN IT GIVES A F 13 CODE. WHAT COULD THAT BE?
Hi.
F13 means Bad EEPROM check, which in simple words means bad oven electronic control. The EEPROM is memory a chip mounted on the ERC board (oven control module). When the board detects that the data stored on the EEPROM is not valid you get this message.
Try disconnecting power from circuit breaker for ten minutes. If that does not work, try longer, leaving oven off for few hours. If that does not fix the problem, then the control module must be replaced.
Regards.
Ginko
When I try to turn on the oven it say f13 err
Most of the F13 fault codes say it is either the Main board or a temperature sensor.
May 10, 2011 • Ovens
11helpful
2answers
Error f13 on my frigidaire oven how do i fix it
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
1helpful
Oven wont work
when i turn onether oven then a bipping alarm and oven will not come on. light come on but not heated up.
Aug 30, 2008 • Ovens
1helpful
Error Code F13 and door locked
press clear for five seconds if that doesn't work then power down for 30 seconds then on if that doesn't work replace the eoc
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
