Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Posted on Apr 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica Minolta Bizhub 250 Authentication issue
I have couple of Bizhub 250 MFPs in my bussiness environment. I would like to know some information about some of the functions:
- Is it possible to disable account check for Copying, but only for Printing?
- Is it possible to disable active directory authentication only for copying but enable for printing?
- Active directory authentication doesnot allow to enter a password that cnotains some characters like ^ etc. (carrot)
I find its an inconvenience to enter username and password each time a user wants to do copy function frequently, also, the username and password entering is not so fast and friendly in Bizhub 250.
Thanks for any input.
Anonymous
Level 2:
  • Expert 167 Answers
  • Posted on May 29, 2008
Anonymous
Expert
Level 2:
Answers
167
Questions
Helped
198016
Points
292
What you require can be achieved though the "public access" settings. This will allow you to control what can happen without requiring a log in.
Konica minolta c652 errorr code c211 - Konica Minolta Bizhub C452 Copier
Your authentication device isn't connected properly or wrong loadable driver or your mainboard have malfunctioned. I'd try re-connecting the authentication device USB connection and try new loadable driver, setup in Service mode and perhaps flashing it with latest firmware could resolve your issue. If all this fails then MFPB is to be replaced.
My konica minolta 250 all in one ask about accout no. and log in
To disable account tracking (ECM), perform the following:
1. Press Utility.
2. Select Admin. management.
3. Enter code. could be one of three: 12345678, 00000000, or 77777777
4. Select Admin. 1
5. Select Account/User Auth.
6. Select User Authentication ON/OFF.
7. Under Account Track select OFF.
1helpful
How much is a fuser unit for a bizhub 250?
Hi donaldterril,
The fusing unit for the Konica Minolta 250 (black & white machine) is around £225 in the UK.
Please let me know if you want to order one and I'll get you the exact price. I'm at home at the moment
and don't have access to our price list.
Regards
m-press.biz
Restriction problem under domain environment(bizhub c280)
call your tech services rep, he will tell you in detail what you are asking..........
have a good time,,,,,
How can i add client pc to scan from konica minolta bizhub 250
HI U must have CD driver to istall twin driver in ur pc and conect usb cable the leed in the right [ + ] will light up if no call ur service
2answers
Slow printing of large pdfs
Sounds like you are just bogging down the Printer's memory.
Your best option is to upgrade the memory.
Smtp authentication - bizhub 250
Firmware can be upgraded by using a 256mb compact flash memory card.
The slot is located on the right side of the machine below the scanner glass. Its in the same area where the fax phone lines plug into.
2answers
Cannot Scan To E-Mail
yes, you can, go to brauser and type your bizhub ip aadress, you'll get a webscope page, there log in as administrator and under network choose e-mailt - smtp and there shold be a place where you can mark, that youre smtp server requires authentication.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
