You will need to change Setup # 0670 to 0. Let me know if you need any more help.You will need to change Setup # 0670 to 0. Let me know if you need any more help.
You can't post conmments that contain an email address.
Remove
the thermostat from its base and replace the batteries. To remove the
thermostat, grasp it at the edges and pull toward you. The batteries are
on the back of the thermostat housing.
With directions go to system. Then hold down 2 blanks on either side of middle for 30seconds this shows you Advanced settings . Read through and find the proper settings
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier. Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
