You can often successfully recover deleted files from a PC, it all depends on what has happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that tells the system where the data for those files is located. The area containing the deleted data is also now marked as free space so it is available for any new files to be written there instead.
If and when that happens, then it is too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
One of the easiest ways to see if you can recover deleted files is to try some good file recovery software. One I used to use is this data recovery program which you can download from site below
http://www.asoftech.com/adr/
So, I hope you can learn a lesson from this
trouble to back up everything important in the future.
But, right now, in order to get back your
lost data, you can use a PC data recovery
freeware that can easily restore your accidentally lost data:
http://www.freeware-fix.blogspot.com/2013/02/data-recovery-for-pc.html
Note: Before you've restored all your wanted
data, you should never save anything new on this PC, If you still want to
restore your data back completely.
Hi there, where did you store your lost data? External hard drive, USB flash drive, memory card or whatever. If you stored data in such places you could manage to do memory card recovery or
Have you ever saved new data on the drive after data loss?
If No, your lost data can be recovered. if you can describe how you lost data in details, I can share more detailed solutions for you.
anyway, no matter how you lost your data, the first and urgent thing is to stop saving new data on the drive before recovery
