The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
The C330 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
SOURCE: Kodak C913 driver using Windows 98
take a look at the system requirements at the bottom of this page
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=13035&pq-locale=en_US
Windows XP or Greater is required. In other words you have to upgrade your OS to XP or better, there is no driver for 98
SOURCE: Gphone Error
first of all, see if the handset recognises the sd card....easiest way to do this is go to MENU > SETTINGS > SD CARD AND PHONE STORAGE and at the top you will see the available size if anything. if nothing, try to remove and then reinsert the media card and then try it again. if thats doesnt work, you will have to reformat the card to FAT32
do this by connecting your phone to the pc and opening your MY COMPUTER icon > right click REMOVABLE STORAGE/DISK > select FORMAT
**if your computer says something like 'no disk available' try disconnecting the device and select MENU > SETTINGS > SD CARD AND PHONE STORAGE > make sure the check bos for 'USE FOR USB STORAGE' is checked****
after that, set the 'file systems' as FAT32 > select START > read the warning > press OK > once complete, disconnect from the pc and try again!
IF that doesnt work, try to test the sd card in another phone to see if the sd card itself is the problem. if you still have the issue but the sd card works, go ahead and reset the phone.
MENU > SETTINGS > SD CARD AND PHONE STORAGE > FACTORY DATA RESET > RESET PHONE > ERASE EVERYTHING
SOURCE: bought 2 gig sd card
First of all, you must be sure that the SD card is formatted with the proper formatting as http://digitalgadgets.com/netbooks/7-in-netbook.htm indicates to be FAT 32. Then you have to down load the indicated file and unzip the file to expose a file called script in the root directory of the SD card. All of this has to be done on another computer with an unzip program installed. Then you place the properly fixed SD card in your SYNET07526, that card goes in upside down!, then you turn on your SYNET07526, and away you go. Read my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Testimonial: "boy boy you are good the diggi gagets customer service never returns there calls and email takes 3 days i have done my homework you are good thanks "
