JVC HD-61Z456 Television Logo
Anonymous Posted on Jun 11, 2010
HOW DO RESET THE HDMI INPUT? JVC , HD61Z456. - JVC HD-61Z456 Television
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3433
Points
16
Set the remote to "TV" and 'VCR". Press the sleep timer once and "0 Minutes" will show up on the screen. Afterward, press and hold the "Display" and "Video Status" buttons simultaneously and then let go. A menu will show up on the screen, then press "#2" on the key pad. A new menu will show up on the screen, then shut the power off. I was told it could take up to 3 times for this to work. Hope this helps.
  • sonidomix Nov 09, 2010
    Thank You for this post. It solved my problem. I was getting only a blank screen when I would connect my computer to it. Had tried everything and was ready to give up. Then I found this post. Thanks Again
What do I do If my jvc HD61z456 TV shows blurry and out of focus?
-If that is mine. I'll buy new one.
-You can fix it if you want to. But most likely will end up to spend more to fix than buy new one.
Good luck
Mai
Jvc projector blue screen
unplug it let it set hit power button plug back in might work for you
How do I reset TV?
reset jvc tv Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... reset jvc tv question. Get free help, tips & support from top experts on reset jvc tvrelated issues. ... one on the Right 2. HDMI input not working ... ...reset television. I have a jvc 42inch that was just going to main logo screen and not beyond it.
[PDF]LCD Television Users Guide - JVC
resources.jvc.com/Resources/00/01/14/YA654ien.pdf
Audio Reset . .... See the included manual on mounting procedures. - JVC is not responsible for ... 2) Remove the screws from the back of the TV. 3) Pull out the ...
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will show you step by step how to easily fix your big ...
JVC TV no signal
IF YOU ARE REFERING TO IT SAYING WEEK SIGNAL IT IS BECAUSE YOU SHOULD BE ON HDMI INPUT FOR TV,go to menu scroll to hdmi -1or2 input for cable hdmi input,i had same thing.
Why my jvc television hd61z456 not showing in high definition
What is the signal source that you are watching on your HD61Z456?
The problem you describe usually happens when you aren't using an HD source or have downgraded the signal by the composite input on your TV. (Composite cables only support 480i SD signals.)
You will only see 720p HD content from HD sources, if you use HD compatible inputs. Some OTA channels are also broadcast as only analog signals (usually the -2 and higher sub-channels). If you have cable or satellite, make sure that you have the HD programming and have tuned to the HD version of the channel.
The HDMI and component inputs both support HD signals.
I hope this helps. If you are watching an HD source and the problem persists, I recommend trying new video cables. Next, check if you are getting interference from your devices by using a cable with a Ferrite core. See http://www.monoprice.com/Category?c_id=102&cp_id=10240 for HDMI cables with Ferrite cores. The cores help block interference. If you have very long cable runs, check the behavior with shorter cables between the source and the TV.
(I am assuming you aren't using an SD set top box (VCR, older cable box, low end digital-to-analog converter).)
Hdmi isn't working on jvc 52z585 tried resetting it with remote it seems like its locking out other devices for like copy rights infringment
hi,
JCV 52Z585 has 1 port HDMI that support 480p
if your input higher your tv will not support.
There are 2 type of HDMI 480p signal, 640x480 and 720x480.
To seting input HDMI to JVC, you should seting input device to default resolution or 480 depend on device (DVD, PC, blueray etc).
JVC Big Screen: Can't change input
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
2helpful
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
JVC THD-50 system
Yes, that is correct. You can either use optical or digital for the audio to the jvc system. They give you 2 options but you can use either, they both work just as well.
2answers
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
