YOu can disassemble the machine and clean the switch and resolver the connections to the circuit board, but it would be easier to call Roland and get the info for the nearest service center in your area.
do you have the owner's manual if not download it-there are /were you tube videos for what your trying to do- they helped me alot - when you plug your guitar into the guitar jack on channel 1 you can't use the xlr input 1at the same time in addition be careful not to blow the audio system there are no replacement parts for this system
Read your user manual about keyboard split. OFTEN the rhythms use the keys below F sharp for the chording of rhythm. When in this mode, you should restrict your melody to notes above F sharp that is to the left of middle C. If you play melody below this it will confuse the rhythm chording. You can likely change the split point of the keyboard, however, the F sharp split is the standard and I would suggest staying with it.
Well Try to make a copy from another Computer then Format a new disk then try.. if not working then.. download from internet exemple....Download Korg TR76 Manual for more instruction ...
A demo on YouTube shows the owner pressing one of the buttons on the left side to select possibly a bank as well as the start.. I could NOT find a manual online to download.
If it is a drum machine, why have you posted this query under Cameras ? You may get more help posting it under musical (and I use the term loosely) instruments.
4. You now have a fully editable copy of the User Manual.
OR...
1. Go to: http://somepdf.com/ and download the "free" PDF to Word converter program.
2. Install the program (be sure to scan download for viruses before installation).
3. Run the program and follow the prompts to covert your file. This program will attempt to keep all images and formatting intact when converting, unlike the above mentioned process.
