Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Posted on Jun 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you find the faulty ink cartridge in a canon mp530. all cartridges have adaquate levels, no blinking, but control panel will not function.
Anonymous
Level 2:
Sergeant:
  • Expert 190 Answers
  • Posted on Jun 11, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
190
Questions
0
Helped
39547
Points
504
Try to reinstall the printer driver software. you can download the printer driver software from your printer manufacturer's web site then restart the computer and printer.
How to set ink cartridges?
How To Replace Cartridge(s)
  1. Lower the Canon PIXMA MP530 printers front cover and output tray. You should also lower its paper output cover to open.
  2. Then, wait for the head cover to open. ...
  3. Push down the empty cartridges lock lever. ...
  4. Slide the new cartridge to its correct slot.
1helpful
2answers
Canon mp530 printer
With the power on to machine and it turned on, open scanner lid by lifting entire top upwards(operations panel lifts up), cartridge mechanism should move to the left to allow cartridge removal, push cartridges down to remove.
here is link to user guide
http://www.usa.canon.com/consumer/contro... cut copy and paste this link will work http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid= 13368#DownloadDetailAct
2helpful
2answers
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
1helpful
I'm trying to use refilled ink cartridges in my Canon MP530, but I get a V (or U) 130 error message. Any thoughts?
CHECK INK
A.
U130
An ink tank that was once empty is installed.
Replace the ink tank.
Printing under the situation may damage the Print Head.
Canon shall not be liable for any machine malfunction or damage caused
by refilled ink tanks.
If you want to continue printing with the refilled ink tank installed, press
and hold the [Stop/Reset] for at least 5 seconds, and then release it. Using
refilled ink tanks are memorized.
* This operation will release the function for detecting the remaining ink
level
B.
i am not sure but is working on 520
1. print mono or print color for color
2.stop
3.ok
4.on/off
  1. Switch the printer OFF
  2. Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  3. Keep pressing this four buttons for 10 seconds
  4. Release the On/Off button (number 4) (Keeping pressing the others)
  5. After a few seconds (when the printer go ON) you can release buttons 1, 2, 3
  1. Maybe step "c)" is not needed
  2. This procedure was used when I refilled the Black cartridge - try using the ColorCopy button instead of BlackCopy button (number 1) if you refill Color cartridge.
  3. Maybe there is no need for all the four buttons - you can try 1 + 4, 2 + 4 or 3 + 4. (or 1+2+4, 1+3+4, 2+3+4)
Set ink cartridge message on canon mp530
1. Set all the printer cartridge both black and color cartridge (including the empty one)
2. Right click on printer driver properties
3. Click Maintenance tab
4. Click on Ink Cartridge Setting mark
5. In pop up menu, select the cartridge which has ink inside (black only or color only). or get more information for set ink cartridge .
2helpful
Canon pixma mp210 printer - replaced ink cartridges with compatible ones - printer working fine except when printing both ink lamps come on solidly, not blinking, and status says there is no ink in...
Dear merryan,
This printer uses FINE cartridge which has memory chip inside that store ink level data. Once the cartridge is EMPTY we cannot restore this data to be FULL even though we physically refill ink until FULL. So the printer keep displays NO INK warning.
Similar with using compatible cartridge, NO INK warning still remain because ink level data has been recorded as empty. Why?. Here is the explanation. As far as I know no third party compatible cartridge produced this printer since canon protect it with the chip. Compatible cartridge that sold in the market is refurbish cartridge which repacked with another brand.
To fix this problem we need to deactivate ink level detection function by holding down STOP/RESET button for about 9 seconds or more for each cartridge. The consequence of this is ink level become UNKNOWN.
Hope this will be helpful to you
Regards,
Xanda
Chip/no chip issue for Canon Pixma MP530
the printer NEEDS ink cartridge WITH the chip
BUT, you can move the chip from the old to the new cartridge, you just lose the ability to monitor ink level....you have to visually check it from time to time
been doing it for months now... works fine, just keep a close eye on the ink when it starts to get low, can hose the printhead for that color if empty
printheads run around $55 or so - so actually, savings in ink will easily pay for a new printhead every now and then, if you screw up  :)
4helpful
2answers
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
2answers
Ink cartridge red light
need original canon ink cartridge not generic
2answers
Canon Pixma MP530
I am in the same situation. When 'Check Ink' comes up, the yellow cartridge blinks.  If I take it out and put it back again, the printer will work.  Then after a while on idle mode, the problem will show up again.  Pretty annoying.
WF
old marine
old marine
ZJ Limited
ZJ Limited
