Question about Goldstar DH504EL Dehumidifier
I have a Goldstar Dehumidifier DH504ELY7 that doesn't pull moisture out of the room. the fan runs and I think I hear the compressor come on but the air coming out the back is cold and the bucket doesn't fill up. does this mean a refrigerant leak? where are the coils that are suppose to get cold? In the front of the unit?
  • Goldstar Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
SOURCE:
Runs but doesn't work (no water accumulates)
It sounds like what you hear working is the fan. The unit also has a compressor; if the compressor is bad or the freon is gone, the fan will run but the coils wont cool to remove moisture from the air.
Jun 26, 2011 | DeLonghi DE500P Dehumidifier
Model BHD 651-C Serial 611TA000375 Problem: Unit comes on, fan operates but compressor is not kicking in. While the fan operates it is not pulling any moisture out of the air. Controls indicate that...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jun 09, 2011 | Comfort-Aire BHD-651 Dehumidifier
It seems as if the unit makes the room warmer. Is this normal?
Yes the heat is a byproduct of the compressor running....there will be a slight overall heat gain...this is very normal and nothing to be concerned about....the dehumidifier passes the air over a cold coil to pull out the moisture but also discharges the heat into the room...so... the net result is heat gain in the amount of electrical energy the dehumidifier is using...
heatman101
Jul 27, 2010 | LG Goldstar LD65EL Dehumidifier
Do i need a filter to run a goldstar dehumidifier DH504ELY7? Don't have manual
No,
If the coils start to plug up just wash them down or vacuum them off....
heatman101
May 28, 2010 | LG DH504E GoldStar Dehumidifier
My DH504ELY7 unit quit working.
look for A fuse probably gonna be internal or a lil breaker or a reset button
Feb 22, 2010 | Goldstar DH504EL Dehumidifier
Unit runs and you can hear the compressor come on but it is not pulling any moisture out of the air
if it seems to be running normally except no cooling , is the fan in the house running????...Is the house Cold and damp???.If there is no cooling and you know that the compressor and everything else appears to be normal then you likely have a Refrigerant leak and that will cause no cooling.....Usually a very expensive repair...if your unit is 5-10+ yrs old you likely need a new "A" coil.
Oct 29, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier not collecting moisture
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jan 31, 2009 | Kenmore 54501 Dehumidifier
Goldstar DH504EL Dehumidifier Logo
1,168 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
