GE remotes are built by Jasco. The manuals and code lists are available here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Does your remote use 3-digit or 4-digit codes? Try ORION 035, 121, 135, 191 for three-digit codes or ORION 0121 0135 0035 for four-digit codes.
1. turn on device 2. press setup (underneath on/off) till red light
stays on the take finger off the button 3. press and quickly release
device button (tv,vcr,etc.) the red indicator blinds off once 4. press
the on/off button (up to 300 times) until the device is to be controlled
turns off the red light blinks off with each button press 5. press and
release enter to install code
HOW TO PROGRAM GE JASRM24912 Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV. 2. On the remote control, press TV once. 3. Press and hold SET until the LED (red light) blinks twice, then release SET. 4. Enter the first four-digit code for your device. If performed correctly, the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again. 5.
Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 through 5, trying each
code until you find one that works.
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
