SOURCE: hotpoint built in dishwasher
Check your air gap on your kitchen sink. If equipped, you will most likely find it clogged. Pull off the metal cap, then unscrew the white or clear cap. You should find your clog there. Replace both caps and remember to pre-rinse the dishes better before loading.
SOURCE: door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
SOURCE: Installing GU2700XTST , I dropped a screw inside the pump area
Follow the series of pictures at: http://www.flickr.com/photos/appliancejunk/731287159/in/photostream/
SOURCE: dishwasher issues
it can be the 10A fuse located in the back of the machine. but.... storage is kind of a problem with determining what is wrong with it.
Mouse can have chewed the wires, moisture can have rusted or corroded some components.
Check the internal fuse first and please check all wiring fo damage.
SOURCE: I have a hotpoint dishwasher, was installed in my house new when it was built in 2004
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
