You flooded water heater wiring compartment with detergent, and the wires were shorting so you turned off power and cleaned detergent. Now water heater doesn't work.
1) The heat from shorting might have tripped ECO reset button.
Open top cover on water heater, and push in red reset ECO button.
http://waterheatertimer.org/images/Jly-022-thermostat2-175.jpgBe sure to re-install insulation and cover.
Other steps:
2) Turn off power. Remove wire nuts. Cut off copper ends of wire, and re-strip each wire so fresh copper shows. Make sure no detergent is on the copper. Use new wire nuts and twist very tight against copper wire.
3) Cut back burned ground wire. Remove ground screw and clean thoroughly. And then reattach clean copper to ground screw.
4) Turn power back on.
5) If water heater still does not work, then test across top two screws on upper thermostat for correct voltage.
http://waterheatertimer.org/images/Jly-022-thermostat3-175.jpghttp://waterheatertimer.org/Test-electricity-to-water-heater.htmlAdd a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
