Onkyo TX-SR604 Receiver Logo
Posted on Jun 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, this is not really a problem. I have an Onkyo TX-SR604 receiver. I had polkaudio speakers RTi8 speakers that are no longer working properly. I am looking for recommendations for new speakers that can handle this receiver's output.
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jun 11, 2010
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767342
Points
24828
A receiver with the specs...
* "90 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz, with a maximum total harmonic distortion of 0.08%"
(*) The only acceptable statement of its power bandwidth in the manual.
... when fed an undistorted audio signal, used properly and not driven abto clipping is not particularly dangerous to any reputable speaker.
Driving any amplifier, even a modest one, into high distortion is more dangerous to any speaker than a high-powered amp pumping pure undistorted power.
Choose any speakers but low efficiency models if you want loud and clean sound.
1helpful
Onkyo TX-SR604: Video in from cable box has taken increasingly longer to display a picture.
I would at least disconnect all units from power for a while and then reconnect to allow the units to reboot.
ONKYO tx-sr605 HDMI CHANNEL 2 INTERMITTENTLY SWITCHES TO STANDBY
Check the Ohm value (4, 8, 16...) on the speaker and on the ONKYO too.
If not the same that is the (big) problem!
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
1helpful
My Onkyo TS-SR604 has a "power on problem" whereby
Check to make sure the speakers are secure, if everything is fine! the problem is in the audio output ic's in the receiver. This will need a technician to take it further to find out how much the cost will entail.
1helpful
I have a Onkyo TX-SR604 Receiver. I get no sound
Hello Fixya customer,
Thank you for your question.
A point to keep in mind here is that Zone II will only feed through an analog source. Since the Video 1 input is using the digital (coax, optical) input that that is your most likely issue.
Thank you for using Fixya, and please let me know if I can firther assist.
No sound
Onkyo is a piece of shit! I had the same f'n problem....
Junk...............
Hum from speakers
I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
Automatic speaker set up tx-sr604
take all the red and twist together and same with blake and put thim in the A speekers no serowund just stario
Onkyo TX-SR604
This is not a problem with the onkyo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
