My samsung yp-u2j 1 GB headphone jack broke off the board itself! Its left channel was not working untill you wiggle the damn thing. im very angry and i blew what? $90? i need help!!!!!
I have one that had the same problem. I solder the jack back on but noticed that the solder pad came off the circuit board. Look at the circuit board and find the component where the connection from the solder pad leads. Using a piece of wire you should be able make a new connection. even after Soldering the jack back on, check to see if the pads inside the jack are bulging out enough to connect to the headphones. The constant wear and tear from rocking the headphone jack back and forth is what causes it to "brake". Could happen when its on your pocket.
Same issue, I love the thing, but now i get NO sound at all. I looked at the circuit board and its completely off. I've asked around a few other sites and no answers yet, I will keep you posted please do the same!! I think you should be able to reconnect it, but i think its more than simply soldering it back to its original position. Anyone PLEASE HELP US!!
