You may want to run the alignment program again. Below are the steps as found on page 84 of the manual found
here.
To align the print cartridges from the HP Photosmart Software
1. In the HP Solution Center, click
Settings, point to
Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the
Printer Toolbox from the
Print Properties dialog
box. In the
Print Properties dialog box, click the
Services tab, and then click
Service this device.
The
Printer Toolbox appears.
2. Click the
Device Services tab.
3. Click
Align the Print Cartridges.
The HP All-in-One prints a print cartridge alignment sheet.
4. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to
OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
5. Load the page print side down on the right front corner of the glass, and then press
the button next to
OK to scan the page.
When the
On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
