Duet washer started getting louder and louder during the spin cycle. When I manually turned the basket I could feel that the bearings were shot. A quick search of the internet confirmed that this problem was no fluke. I found an illustrated parts breakdown of my washer online, and saw that Whirlpool only offers a replacement rear tub assembly, at a cost of $408. Needless to say, I was pissed off. I paid about $960 two years ago for this machine, and now it will require $6-700 in repairs. Unacceptable. So, having a mechanical background, I started to tear into the machine myself. I tore it all the way down to the rear tub half. I found what appeared to be the problem with my machine, hair. Hair worked its way to the bearing area, slowed unseated the seal, and then acted as a conduit for water to enter the bearing cavity. The seal itself actually looked fine. Yet the steel hub that the bearings are pressed into was badly corroded, as were the bearings, and even the driveshaft had corrosion on it. I pounded out the cheap factory bearings, cleaned up the bearing cavity and driveshaft, and replaced them with some higher quality Toyo's from my local bearings and drive store, P/N's 6206ZZC3 & 6205ZZC3. Unfortunately they didnt have a suitable replacement seal in stock. I didnt damage the factory one too badly upon removal, so I straightened it up with a couple of hammer taps, made sure it sealed nicely against the driveshaft, and reused it. The new bearings cost me $20. I made sure I sent a nastygram to Whirlpool, they offered me a replacement rear tub for 50% off, I told them to stick it. Hopefully I get at least 3 more years out of it, I've already started looking for my next machine, I'm likely going to buy a SpeedQueen. Anyways, if your tub bearings are shot and you have the will, they can be replaced yourself for a fraction of the cost of a factory rear tub half. My advice, take notes during disassembly, keep all the hardware from the different components you remove separated from one another. Dont be afraid to use permanent marker to write reminders directly on the components as theyll be hidden inside the reassembled washer when done. I did the repairs by myself, having a helper wouldve made things much easier. As for tools, I was shocked at how few I actually needed. A nut driver or torx apex, a 1/2" socket and rachet, some slip joint pliers, a wrench to remove the drive pulley, and a hammer and punch to remove/install the bearings.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Chornic Hair Straightener Brush Instant Magic Silky Straight Hair Styling...
