Well since you have a degree I'll skip all the hand holding stuff. You need to remove the front back and top and then remove the power input,ballast and emi shield or whatever you call it. now you should see the main board. You could have jarred loose the connection between the main and dmd board or broke the solder on either boards where the connection is. Check with a magnifying glass or microscope if you have them. The main board kind of plugs into the bottom of the dmd board.If the solder looks intact, reseat the main to the dmd board. That is one possible fix. Another fix-- you could remove the little silver clip on top of the lens assy, unscrew the screws that hold the dmd on, take the dmd apart and clean the contacts that are on the part that looks like a cpu with a mirror in the middle and clean the contacts on the board (with board cleaner) put it back together and hope for the best. If none of the above work, then the main or dmd assy are shot.
