LG 42LD550 42 in. TV Logo
Posted on Jun 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a LG 42LD 550 just got it, couple day, it began turning itself on & off, the LG start up screen comes on, its not responding to the remote or the switches on the TV, any idea what is the problem??
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Jun 10, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1183269
Points
12747
Yes its faulty. This is not me being funny. The 42" TV has had many faults and weas under recall. LG does not mean good life. It means lotta garbage. If this is new take it back and have it replaced. Preferbaly with a different brand. If it was second hand it has to have minimum guarantee and be covered up to 7 days for colling off and trial period.
Get it back fast, the repair cost is sky high ( $600)
Please rate my help++++Thanks for using FIXYA
I have a lg plasma tv a few days ago it stop working no picture only audio it's a black screen the picture looked showy the second time i turned it on before turning of by itself
If you only have it since a couple of days, don't mess with it. Claim your warranty; get it changed, it is a vey Bad Buy. If they don't want to change it, at least get it repaired as soon as possible
My 1 yr old LG smart plasma tv after about five minutes of watching recently began flashing sidebar characters every few minutes. First one side than the other side then the bottom side of tv. After...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Lg prada ke850 black screen
My Phone has done that a couple of times before. It would slowly start turning off more & more often then it wouldn't turn on with the same problem as you.
Turns out it was the battery as it was a couple of Months old & was out of warranty.
Yellow Screen
Furst, check the video signal cable, if you can, try a replacement. Try removing and then refitting the original, sometimes this clesans the connections
19helpful
5answers
LG viewty Touchscreen problems
I have the same problem. But i had solved it. I use a lighter to burn on my viewty's touch screen, and it is working properly again within 30 secs. And ofcourse, do not burn the touch screen without a screen protector. Hope this solution would help.
1helpful
My Sony SDM N80 screen has turned yellow!
Well, I have 2 of these monitors and one began acting in a similar fashion right before the cable went bad. I acquired a replacement from another person with a broken monitor but I believe this site sells them too (but they aren't cheap).
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=SDMN80
Screen changes and no response to touch
Sounds like the machine has been wet/moist have you tried drying it in a sealed bag with several silica gel bags for a couple of days?
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
