Faberware FCP240 Coffee Maker Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced thermostat,year ago,,
Worked fine,,quit last week replaced a withh a new thermostt gaain,,,this time nothing ??? faberware fcp240
Ronald Callahan
Level 2:
Scholar:
  • Expert 176 Answers
  • Posted on Jul 26, 2010
Ronald Callahan
Expert
Level 2:
Scholar:
Answers
176
Questions
0
Helped
40050
Points
219
Hi look at the fuse, also check your cord. Good luck. Ron
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
789
Points
Need to check that thermal switch is securely against the bottom of the coffee pot. If that is good reverse the terminals
How do I trouble shoot this problem?
sounds like a loose wire could be main power or in tstat
COFFEE POT
Hi Cynthia. I sell the base for 8.00 used and 2.00 S/H. I have to know if it is 3 wire or 2 wire. [email protected] For feedback my eBay is ron622c
Stopped working
There are a few things that can be wrong with it, All require taking the base of off. If you want to talk with me a [email protected] Good luck. Ron
1helpful
2answers
Coffee is not hot
Either you have a corroded electrical connection (probably in the plug) or an element is bad. Try cleaning both ends of the removeable plug until they are shiny.
I bought a new percolater two years ago, and the
Yours is probably a China pot. They are inferior to the USA. I suggest you go on eBay and buy a used one. that will last for years. bobbyone
1helpful
Last year my gable fan seemed to work fine. I
As it's protected by circuit breaker it also might be fused, so check for fuses.
Next just dig to the wiring and measure the resistance betveen Live and Neutral using simple multimeter. If there's no reading then there might be a small fuse (or thermofuse) attached to the windings, make sure this one is fine, if yes then motor windings are burned and you'll need new fan, otherwise just replace the fuse.
Good luck
Fuel system
it may work again but that is only temporary it sounds like the fuel filter is clogging up
Electric cord
You can use a computer connection cord.
Top Faberware Coffee Makers & Espresso Machines Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
john h
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
