HP Photosmart D5360 Printer Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've lost the manual for my HPD5360 printer and the new ink cartridge will not align. Any ideas? Thanks. [email protected]
Anonymous
Level 3:
  • Master 435 Answers
  • Posted on Jun 18, 2010
Anonymous
Master
Level 3:
Answers
435
Questions
Helped
259308
Points
1007
Hi, you can download the required manual from the link below:
Download Manual
Also, please refer to the link attached for detailed guide on replacing the ink cartridge:
Replace Cartridge
Anonymous
Level 3:
President:
  • Master 2,185 Answers
  • Posted on Jun 13, 2010
Anonymous
Master
Level 3:
President:
Answers
2185
Questions
0
Helped
519897
Points
7044
Hello there,
Here is the direct download link to your manuals, be it Basics, Setup or User guide:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3194503&lc=en&cc=us&dlc=en&lang=en&cc=us#
Hope this helps.
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
2helpful
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
4helpful
2answers
Carriage Jam - HP Officejet J3680 All-in-One
the silver bar the carrige slides on has lost all its lubrication. Try putting some chapstick on the silver bar
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
2answers
1helpful
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
2answers
1helpful
3answers
It will not align ink cartridge
the printer keeps saying "press enter to align cateritage" so i press enter. there was no black ink so
I went to the printer store and bought a refill on black ink...
Put the refilled cateritage in the printer and again its says allign cateritage. It takes about 5 minutes, and it prints out a piece of paper and says alignment failed....
How can i fix this occuring problem?!?!
Thanks
2answers
Lexmark 2500 and turning off alignment
nope..it's part of the reset for any printer..and a good idea, to ensure that you are working with a printer that is calibrated..
Lexmark X6170 Not Printing on Left Side of Paper?
If the pages printed from the printer directly comes out OK then you may need to update the driver for the printer. If the pages printed directly from the printer menu have the same problem then contact Lexmark again explaining everything you've done. If the person is still not helpful ask to speak with someone who is more able to assist you. Hopefully still under warranty.
Hope this helps!
k24674
Grand Canyon Tech
Grand Canyon Tech
